Advice on late Type 3 motor
https://forums.aussieveedubbers.com/threads/107211/advice-on-late-type-3-motor
Volkswagen4me ·
Hi all,
I'm considering buying a 1969 Type 3 fastback (the one with the longer, pointed bonnet) which I've come across. The only thing I'm a little unsure about is the motor - I've attached a picture of it.
Can anyone tell me what I should look out for on the motor, or where there might be any problems or problem areas which could arise in the future?
Much appreciated,
Lincoln
1500S ·
Volkswagen4me wrote:Hi all,
Actually a 1970 model.. released around August 1969. The 1969 model still had short bonnet.
Volkswagen4me ·
Thanks 1500S, it did have me a little confused when I was told it was from 1969, since I thought the longer-nose model only started coming out in 1970.
Calcool ·
Engine is possibly the least of your worries
It is in the car and looks complete and does not look like it has been messed around with.
Check the dipstick for oil level and condition
Look for oil leaks and exhaust leaks
Does it start and idle smoothly? Does it rev up smoothly and come back to an idle?
Check compression even see if you can make it stall by covering the tailpipe usually means a tight motor.
Listen for any loud knocks or clacking noises whilst running can be big or little ends or poorly adjusted tappets!
Good luck!
David
PS the grass looks nice and green if they look after their car as much as the lawn you might be onto a winner!
Volkswagen4me ·
Thanks for the advice David, I'll take it all onboard when I go for the inspection.
Much appreciated!
Lincoln
