Non VW Engine Fire
https://forums.aussieveedubbers.com/threads/107215/non-vw-engine-fire
DubbyFan 路
Yep happens to other makes as well! Late-ish Nissan ute left parked, local lady visited a friends had a cup of tea and came back to an inferno, ignition not left on!
Joel 路
Its a TF Rodeo 馃槈
it did the owner a favour setting fire to itself.
I had a brand new one for a while in 2002, those 2.2 engines were the biggest turds
no where near enough power, with any sort of load they can barely move.
Had to get a new engine at 135K.
donn 路
That's probably why they lightened it by removing the tray and the number plates, then the power to weight ratio is probably getting close to adequate. 馃檯
vlad01 路
Joel wrote:Its a TF Rodeo 馃槈
this will solve that problem lol. 馃槀
http://www.rodshop.com.au/index.php/holden/rodeo/tf-holden-rodeo-ls-conversion-kit.html
mackaymanx 路
My brother lost his Hyundai Getz recently to an engine fire, cruising along and it started to miss, then it cut out completely. Pulled off the road and popped the bonnet, fuel everywhere. Went to the boot for his torch and by the time he got back to the A-pillar the whole lot went up, nearly scorched the hair off his arm.
helbus 路
Same thing happened to a friend of the missus. Her Peugeot was just driving along the Tollway, and started dying, so she pulled into the emergency lane, and within 30 seconds the front burst into flames, the scrub caught fire on the side of the road, the Fire brigage came quickly, because it was on the tollway camera, and the whole plastic front of the car was disintegrated in minutes.
vlad01 路
had a falcon burst into flames, the guy that bought it was loading it on the trailer. Switched it off and about 30 later after getting out of it it burst into flames.
got my fire extinguisher. most useless thing!! did nothing to stop the fire, so I ran to the front of the property and got a hose ran back and scrambled to get it hooked up to a tap.
Once I got water on what looked like a fuel fire it put it out quick smart.
The front of the car was F'd. in about 3 min max to looked like the pic above.
I have no idea how it burst into flames considering the engine only ran a max of 2 min to drive up the trailer and was still stone cold and the fact it was off for half a min before it when whoosh!
Had my holden piss fuel out from the new aftermarket hoses on very cold mornings. The hoses shrunk due to the cold and made them loose but they were super tight when at above 10潞c
So I used some genuine 22 year old hoses because they were better until I could find someone that sold descent brand EFI hose. Using codan hoses with good results.
people make sure your hoses are good brand and use proper clamps of the correct size.
Joel 路
Here's one type of vehicle you do not want to be anywhere near if it catches fire......
vlad01 路
3:52
holy crap! look at that cylinder go. Thats lethal!
DubbyFan 路
How's the one at around 3.57 takes off like a rocket!
So would they be LPG cylinders like we use for gas stoves?
vlad01 路
nah I reckon acetylene.
LPG bottles dont explode that violently, or explode at all as the pressure is relatively low. They just vent though the safety value most of the time.
I have seen a video of an acetylene factory go up and the exactly same thing happen, bottles were blowing up with massive explosions and taking to the sky like rockets.
Acetylene is under 10s of 1000s of PSI in them and its a highly volatile molecule and pretty unstable.
