Super simple one today.
The rear wheel bearings, are they pressed onto the axle or are can they be replaced just by removing the brakes & seals etc.
Cheers, Allbones.
Allbones 路
Aussieveedubbers 路 Tech Talk
https://forums.aussieveedubbers.com/threads/107219/swing-axle-rear-wheel-bearings
Allbones 路
vduboy 路
Allbones 路
Sorry, should have been more specific, it is a swing axle.vduboy wrote:You have to take the outer cv off the axle first, (I'm assuming Irs rear end), then tap/press out the axle towards the gearbox, knock the bearings out and knock in the new ones. Then tap/press the axle back through the installed bearings/seals. If its a swing axle I have no idea! 馃榾
ian.mezz 路
Allbones 路
Had a look around and it was mixed, some say use a puller others claim pressed (Atleast the majority say puller which has me pleased)ian.mezz wrote:think you just hit housing and bearing pops out ???
joel will knowor google youtube
ian.mezz 路
hellbugged 路
psimitar 路
matberry 路
Allbones 路
