HELP - For the life of me I cannot remove the Allen Key door hinge bolts on my type III. The bolts are starting to become rounded.
Ideas???? Please!!!
tintoy 路
Aussieveedubbers 路 Type 3 and Karmann Ghias
https://forums.aussieveedubbers.com/threads/107265/allen-key-door-hinge-bolt-removal-help
tintoy 路
donn 路
68AutoBug 路
tintoy 路
1500S 路
Make a flat head punch from a piece of 1/2" diameter steel x about 6" long. Give each screw a few hits with a hammer on the punch to break the rust on the thread and underneath of head. Maybe use an impact driver as well to undo screws.tintoy wrote:Thanks guys will give it a try however will be a task as bolts are set inside the pillar.
empi 路
vlad01 路
I can vouch for this method. Works well.donn wrote:Hmm, how to describe this method that I have used , though not on hinge bolts. Get a small coal (cold?) chisell, sharpen it to a "blunt" angle (about 60-80 deg) then holding it on one side of the screw head and at an angle that will allow the chisel to bite into the head of the screw start taping it firmly so that it turns the screw in the direction to unscrew it (anticlockwise ?). The screw will loosen and then you can use the Allen key to finish the job. Mind you, the screw head will be stuffed. 馃檮
bushed 路
vlad01 路
