1971 BEETLE IDLE Problem
https://forums.aussieveedubbers.com/threads/107355/1971-beetle-idle-problem
chrissys beetle ·
we have a 1971 standard beetle
we had issues with it idling so we got the carby reconditioned
since then the car idles ok when the auto choke is on ,once warm its a different story
it idles poorly and always stalls if idling for any length of time
I increased the idle speed but makes no difference
Any suggestions please
nbturbo ·
What did you do to adjust the idle speed? A pic of your carb will help.
my guess is an air leak somewhere
increasing the idle speed is the wrong road to go down
It idles ok when the choke is on because the richness is compensating for the leak
once it backs off the leak takes over.
99% you have white spark plugs
nbturbo ·
I'm guessing some other causes- idle mixture and idle air speed correction setting screws not properly set.
modnrod ·
These blokes know their poop.
So, a huge thanks for making this available to all.
http://www.vw-resource.com/carb.html
U have air leaks
