All hard lines and fittings included, you will just need to cut new air hoses.
$200 the lot, will split .
Willing to swap for,
x1 12v flywheel
x1 12v starter motor
x1 manual pedal assembly 68 onwards
x1 gear shifter
x1 clutch
x1 gearbox throwout shaft lever
Call Chris on zero467 688 85five . Pick up only 4012 Brisbane
h 路
bargains a plenty 馃憤
DakDak67 路
Yeah Pauly, it should be twice this.
pfillery 路
I had all this same type of stuff as spares from my semi when I had it. Some is not easy to move but some is gold. Good control valves and clutch actuators are easy to sell in the USA, there's a lot of semis over there, only a few die hard fans here. Starter motors are unique to semis so hard to find. Lee (68autobug on here) might know someone who needs it, he has a semi as well.
