Fitting Kadron Manifolds to Twin Port Type 1 motor
https://forums.aussieveedubbers.com/threads/107451/fitting-kadron-manifolds-to-twin-port-type-1-motor
mossman ·
The Kadron manifolds for a twin port motor dont have the hole for the locating lug on the heads that the original banana manifolds do.
Should I grind the locating lug in the heads down or drill a hole in the aluminium manifold?
A good set of multi grips should be able to pull the pin out.
That is what I did.
mossman ·
Thanks Bizarre. Removed them with vice grips after freeing them up with a hammer.
