Door Handle Help Needed!
https://forums.aussieveedubbers.com/threads/107457/door-handle-help-needed
scootissimo ·
Hey aussiedubbers..hoping someone can help, how do I remove the inner door handle on my 72 superbug? I can't see any screws, I've tried to "pop" the plastic surrounding bit off but no luck, don't want to pull too hard in case it breaks..trying to get to the door cards for repairs. I have read that the arm rest will pull upwards and off if I can get this handle off..
Sam in Portland
Performance Upholstery ·
You need to pop the inner plastic bit off.... The bit under the handle where your fingers go when you open the door. Get a flat blade screw driver and put in on the gap at one end and pop it out. There is a screw under that.
