Just lost another exhaust stud today. Replaced one that was missing a few months back, tightened everything up. Some other exhaust nuts were loose again.
Do I need to use bigger studs or some sort of thread locker? It's on a 1600 kombi engine. Is there a better nut/bolt/stud combo?
.......and new studs with "Screw Lock" (low strength).
shokwave2 ·
I had an exhaust stud come loose at the Sydney VW Drags this year. I used a timesert with threadlock and it hasn't pulled or loosened once yet.
grumble ·
have you tried helicoils in them,we use them in the trade with great success?
bajachris88 ·
As long as its not stripped, I can't see why a thread locking compound (as long as it cold handle high temps) could be used.
psimitar ·
How loose is the thread in the head when you screw the stud in? Cos galvanic corrosion between the steel n ali along with the heat is pretty good at killing the thread in the head.
Either helicoil or time-sert are the best ways to fix unless you know someone good at TiG welsing ali 🙂
