1990 T3 Syncro Transporter $8K SOLD
https://forums.aussieveedubbers.com/threads/107572/1990-t3-syncro-transporter-8k-sold
mackaymanx ·
Vehicle - 1990 T3 Syncro Transporter
Location - Mackay Queensland
Rego - car is registered until July 2015
Engine - 1997 EJ22
New -
Timing Belt (Gates) Including tensioner and pulleys
Water pump
Front pulley seal
Flywheel seal
Cam seals
Plugs
Thermostat
Rocker cover gaskets
Pressure cap
Fuel Filter
Alternator belt
Air filter
Conversion Parts -
Unicap Adapter plate
Smallcar sump
Smallcar engine mount
Smallcar throttle cable(modified to have adjuster)
Smallcar coolant tank bracket
Smallcar coolant pipe
Smallcar exhaust header
Smallcar VSS
Commodore air filter box
Plastic coolant lines replaced with hydraulic suction line (SAE 100R4)
Brakes/Clutch -
New slave cylinders rear brakes
Rebuilt front brake calipers
New brake hoses F/R
New clutch master cylinder
New clutch slave cylinder
Driveline -
New-
Rear wheel beaings
Input shaft seal gearbox
Drive flange seals(cv) F/R
Gearbox/diff oil
Front outer cv boots
Shift linkage has been rebuilt
Suspension -
New -
Old man emu shocks F/R
Top control arm bushes (F)
Bottom control arm bushes (F)
Top ball joints
Bottom ball joints
LH tie rod
Powerflex rack bushes
Caster/track rod bushes x4
Body -
This van needs paint, I have primered some of the bare spots. Van had been semi preped for paint on the front and LH side but left sitting in a shed for 7 years before I got to it.
Contact -
Brent
Phone zero 4 zero 39 zero 2165
E-mail manxdune@yah00 dot com dot au
Price - $8 000 neg
Alloy Tiguan wheels are included in sale , I have the standard steel wheel with good tyres to go on it if wanted
Other -
Gearbox has been replaced at some stage(factory replacement I think) with an AVN code box. This is the same as the standard Australia gearbox except the 2nd gear ratio is lower. Gearbox casing appears to be all aluminum not magnesium.
Edit I double checked the gearbox code and it is actually an AVH which is identical to the AVN ratio wise.
This is NOT an ex Telstra van so it has all the seat belt mounts and RH side windows. Seating capacity is 2, but I have vinyl middle and rear seats to match if wanted but missing seat belts and rear seat mounting bolts.
Has a towbar
New windscreen
No diff locks
No decoupler
No aircon
No power steering
RWC if sold in QLD
mackaymanx ·
Picked up a parts van on Monday so I was able to replace the damaged sliding door with a good straight one. Parts van also has an in dash aircon unit which is available if wanted.
mackaymanx ·
Price drop to $8 000, I have picked up another set of Tiguan alloys so it now comes with a set plus a spare rim.
Engine now is a 1997 EJ22 as the previous engine was a little smoky.
mackaymanx ·
Got a roadworthy today but unfortunately the sale didn't happen, so car has current roadworthy and rego is until 18/09/2015 not July
mackaymanx ·
Bump
mackaymanx ·
SOLD
