WTB - REAR WINDOW BODY RUST REPAIR SECTIONS
https://forums.aussieveedubbers.com/threads/107670/wtb-rear-window-body-rust-repair-sections
kuta ·
Chasing a couple of cuts to repair these rusted sections on a 59 Beetle. Maybe someone has a body they could cut these out and send to me or I could pickup in Melbourne.
Thanks Sean.
kuta ·
Seriously nobody out there? Just to cut out a small section enough to weld in there. Must be someone with a rusted beetle that is rusted out in all the usual places but not here?
Special Air Service ·
I an most probably help you out if you can wait until late December early January ? would have to post them to you though..... but surely someone closer would have something for you.
Are you on facebook ? there might be some options on there for you
oldskoolguy ·
Don't know if this helps but as SAS said there is options out there.
https://www.facebook.com/photo.php?fbid=10205576253632113&set=gm.883626855001808&type=1&theater
https://www.facebook.com/photo.php?fbid=10204730320285561&set=pcb.884719991559161&type=1&theater
bushed ·
got a 71 rear windo if any one can confirm same curve ??
also are the tp same as bottom ?? increases chances of a find...
kuta ·
Thanks guys for the replies. I tried the link to facebook but it didn't seem to work.
SAS I may have to take you up on your offer if nothing comes up.
Not sure about the 71 being the same.
no worries......
if you are on Facebook, you'll need to join a few VW groups to be able to get access to stuff.
try
VW Buy/Swap or Sell - Australia https://www.facebook.com/groups/714103505287478/
Aussieveedubbers https://www.facebook.com/groups/aussieveedubbers/
VW Restorers Australia https://www.facebook.com/groups/696877697020516/
join up then post your wanted adds on some of these.
Brendan
MR930 ·
http://www.justkampers.com.au/windscreen-repair-panel-2-piece-for-vw-t2-bay-1967-1979.html
Something like this do the job?
roofchop ·
Check the radius, top and bottom (cardboard template)
If the same I have the top bits that will do the job! (upside down)
Dave
kuta ·
Is your offer still available Special Air Service? I've had no luck finding these.
Grey 57 ·
Hi Kuta, I maight be able to help you with these body cuts. I have a 63 that's probably going to get the chop soon. I will let you know in a couple of days. I am located in Cowes Phillip Island Vic
