Almost certain the Wilwood caliper is difficult to get registered
vwo60 ·
All that effort and it still is a solid rotor, you would think that any brakes that purports to be a performance brake would be ventilated.
turboboy ·
Why is the Wilwood caliper is difficult to get registered
vwo60 ·
Not a standard part that has passed through the ADR process, most do not also have secondary piston seals so they are illegal to use.
If you are going to modify a car - it is SOOOOO much easier if you use a product from an ADR approved car
Example - using a Scheel seat that came out of a RS2000 Escort rather than an Ebay special.
That way it is only down to the mounting method rather than the item itself
jobie ·
Thanks for all your replies.
So where does it leave someone looking for a brake upgrade who wants something better than the basic kits (cheap but hardly attractive) but not got the coin for a CSP kit?
Any suggestions?
depends what you want to do and what PCD you want to run
Straight out easiest is a pan swap for a late 4 bolt pan
If you want to stay wide 5 then the VVDS, although aftermarket, has had good results in getting engineering approval
Turbo54 ·
I would not do ANY dealings with airkewld ever again. There parts have never been engineered by anyone and it is hard as f#$%^ to get any info on the manufacturing process that they have gone through in production.
When you ask questions your either not answered or basically told not interested. I am currently going through the process of having drop spindles engineered and jab had to start from scratch as they won't hand over any info.
Run a set of ford, Holden, Mazda brakes, much easier to do and engineer and bigger wheel choice. Especially if you go ford 114.3
vwo60 ·
Why choose brakes manufacturer has not done the engineering on his product, I spoke the other day to VVDS about a set of there five stud brakes for a friend, you are also on your own there engineering wise as he told me they do not have a engineered drawings, heat numbers for the material or the calculations for the design, you are on your own with every possibility that the engineer will not accept responsibility for the brakes, I went through the whole process with my engineer who required all of the previous mentioned things. how all these after market brakes get on the road is beyond me.
jobie ·
I am sticking with the wide 5.
So who does produce a fully engineered disk brake kit for these things???
If I go more power i need to upgrade to a disk kit but which one. Asthetics are important but I'm thinking that I might not have much of a choice.
I think I will stay away from anyone who can't provide some sort of compliance paperwork. If I stick wih the ford, holden, mazda etc option is it only the calipers that I need to worry about or are there other components that I need to thnk about compliance wise?
hus22l ·
Huge market for this. No suppliers
LUFTMEISTER ·
CSP brake kit is tuv approved, which is one of the toughest standards in the world. But apparently this is not enough for OUR beloved engineers. Go figure, oh and they get to put there hand in your pocket to tick & flick approval. No conflict of interest there. My2c
vwo60 ·
Again it is the unknown, does CSP provide all the information so the engineer feels confident to take them on, if you get no engineering documentation you have no idea what and how it is made.
jobie ·
Okay. Can anyone tell me which disc brake kits come fully compliant to Australian standards (in particular I'm after Vic compliance) but all states.
Maybe this site could do with another category where complianced components can be listed (sub categories included). Or is this available already at another site?
I'm sure there would be many who have fallen into the trap of spending a lot of coin only to have to spend a lot more coin on getting their cars registered. I have even spoken with some specialists who are not sure if the product they sell is legal!
LUFTMEISTER ·
Sorry to tell you but you will be at the whim of which ever engineer (they never have set rates) you contact first. He may charge you a little or a lot (depending on what bills he has that week) and the cops could still send you over the pits and THEIR engineer can fail you if, in his opinion, the mod is not safe. Thus voiding your insurance (if you can get coverage) and devaluing your asset. Yet car manufacturers (company engineers) can build faulty cars that kill multipule customers and no one gets charged. Great system hey. Good luck. My2c
nils ·
The CSP kit is apparently approved, I tried all the Aussie suppliers of these kits when I did the brakes on my Baja and not one of them could supply me any paperwork proving this statement.
In the end I changed to a regular stud pattern and used factory parts from other vehicle manufactures.
The bad news Jobie is, there is no such thing as a bolt on kit in Australia.
Governor ·
The CSP kit is NOT approved
As Luft said its up to the engineer doing the inspection.
As far as I am aware there are NO kits that come with approval.
vwo60 ·
If the suppliers were smart they could supply you with all the documentation to take to the engineer but they choose not to, great cutomer service, that is why i made and engineered my own.
cnfabo ·
vwo60 wrote:If the suppliers were smart they could supply you with all the documentation to take to the engineer but they choose not to, great cutomer service, that is why i made and engineered my own.
Hi vw o60 do you have some detailed pics of yours
Thanks Fabo...
Governor ·
Again as far as I am aware there are no parts from overseas that have a blanket approval.
Things such as beams or the Red9 suspension kits are not approved it depends on the engineer who inspects it or approves it, but as mentioned above what one engineer approves, another can say its not approved and that is in each state never mind trying to get someting approved in one state transferred to another!!
Now on another note even aftermarket wheels that dont have ADR could be deemed illegal!!
LUFTMEISTER ·
Welcome to the contrary nanny state.🤪 They want everyone to be compliant, but they make it as difficult and expensive to comply. That's how bureaucrats deal with individually. My2c
vwo60 ·
AS they should, you need to comply with the engineering standards, it is not a cheap process, as i said you need all the enginering documenttation to submit to the engineer, this is another point, most places are only an approval station not an automotive engineer, idiots in brisbane approve the empi brakes but they are not an automotive engineer, red nine front end has not been destructivly tested, this is the requirement form the automotive engineer i use, so all the kombi ones running around are not legal. no insurance or third party, suppliers should not sell the items if they are not fit for the road.
LUFTMEISTER ·
What a crock!!. Your engineer might not like them but the engineers down the road says there great (hence the problem for the public) Those parts are used all over the WORLD and I don't see any of the VW websites/communities complaining of major failures or deaths from these parts. Destructive testing is an old school approach. Computer modelling and design has replaced this approach (thats why they don't crash test Bugattis - are they illegal?) How about some data/facts that says these parts are unsafe instead of just bagging and trying to ban them. Evidence vs Heresay , which one holds up. My2c
hus22l ·
So anyone got disc brakes approved in NSW?
What brake system?
who did you use (engineer)?
How much did it cost? (Engineering certificate)?
Maybe those interested in improving their ability to stop, and improving safety for all road users, should get together and approach an engineer in bulk. Surely if we had 5 people with similar cars and the same brake set up we could minimize overall costs.
I just want to be able to stop when that dog runs into the road.. Rather than run it over slowly.
It looked promising from what I remember, I haven't reread the thread.
vwo60 ·
Computer modeling does not replace destructive testing, are they an item that has been through the ADR process, no they are not, as such they need all the engineering done correctly, if your engineer is prepaired to that responsability for them good on him, it will all come back if some thing happens, stand by what i have said. I see there are no Bugattis in Australia , is that because crash testing is a requirement here.
LUFTMEISTER ·
If the laws an arse, it will be ignored. That is why god gave someone people logic and not a script. No Bugatti = just shows me again how stupid Oz rules are compared to the rest of the world. Sad but true. My2c
vwo60 ·
All good to ignore the law, in the end it is the responsibility of the driver of the vehicle not the vender to make sure it is complied, as for logic, god distributed that very sparingly and that is why we have these rules, have an accident and end up in jail just like the guy in WA who killed his three year old son because of an ileagle modification.
hus22l ·
...and Back to the WA locked diff.
vwo60 I understand you are a terrific guy and play by the rules. Do you have disc brakes? How did you do it? Who did you speak to, what did it cost ( I am not suggesting anything untoward, so don't misinterpret that).
I want disc brakes. I just want some pointers from people that have done it. Or are all these cars at the local shows and in magazines all illegal ? As I said earlier, there May be a way we could approach an engineer (as a group of like minded people) to get a set approved so this problem can get someway to being resolved and people with these old historic cars can drive them in modern traffic (where zippy cars and young driver don't understand you might not be able to stop in time when they cut in).
LUFTMEISTER ·
Yes, I too would be interested in a fully costed & time frame involved analysis of a correct & legal wide 5 disc brake conversion on a link pin beetle.
Thus all the VW outlaws now out there, can safely cruise this wide brown nanny state via the road of self righteousness with our head held high and our wallets empty. My2c lol
(This what happens when you produce too many lawyers and insurance brokers in your country.)
hus22l ·
Ok well we got two people so far , but luftmeister I am in Sydney you are Qld?
Any other ideas or suggestions?
LUFTMEISTER ·
Go with the CSP kit it is ISO approved to international standards except of course in this little backwater called Oz.
vwo60 ·
Concept, selection of rotors, discussion with engineer, cad drawings of front and back aluinium billet hubs, approval of billet hubs drawings by engineer, machining of front and back billet hubs, discussion with engineer about selection of calipers to suit 20mm thick rotors and use standard master cylinder, purchase calipers, cad drawings of caliper brackets, approval of caliper brackets by engineer, machining of caliper brackets, conditions of installation by engineer, IE type and grade of bolts to be used, completeion of installation, inspection of brakes and test, because of all the effort involved the car passed the brake teast first time along with the correct back to front brake bias, resalts, a vehicle that is blue plated and legal on the road in Queensland, time frame, six months, cost of approval $450.00, this included a seat change and two seat conversion, seat belt installation and engine capacity increase all done at the same time. Do not be in denial about the legal implications of vehicle modifications as there is alway potential for that accident to happen. those who think otherwise are fooling thenselves.
