Aussieveedubbers · Bugs
Handbrake cable size
https://forums.aussieveedubbers.com/threads/107719/handbrake-cable-size
Josephshelley1vw ·
Hi all.
Just having some trouble finding the right size handbrake cable for my 67 beetle. Vollks are offering a 68 and 72 inch but apparently there are allot mor than just two sizes. Also have heard that the longer (72") ones are for IRS and shorter (68") ones for swing arm setups.
Just wanted to be sure before I order a new one.
If all else fails I might just pull the other one off and measure that, which seems like I'll have to do that anyway as I've also been told that it is advisable to replace both at the same time to avoid weakness.
If anyone could provide some clarity that would be great
Joe
g'day and welcome
Definitely do both
Have a look here
http://vwparts.aircooled.net/SearchResults.asp?searching=Y&sort=5&search=emergency%20type%201&show=100&page=1
Pretty sure you need the 1965-1967 style - 1723mm
Other wise give VVDS a call on 02 9789 1777
Also put up youur location in your profile and will help us guide you
grumble ·
Give Tooley Imports in Hornsby or Micks Motors a call,they are both great to deal with and their knowledge is great.They will be able to sell you the right part.
Phil74Camper ·
I think you will find an Aussie '67 is the same as a Euro/German '64 and earlier. The Euro models changed the tunnel in '65 and went to the lever heaters on the handbrake; Aussie VWs did not.
Get the one for '58 to '64.
