play in steering box
https://forums.aussieveedubbers.com/threads/107745/play-in-steering-box
clyve ·
Is there anyway to stop play between the input and output shaft on a squareback sterring box. And are they grease filled or oil?
Cheers all
Clyve
psimitar ·
Gotta be similar to T1 and T2 boxes so should have both worm and roller adjustment.
As I'm not familiar with T3 steering then I'd need a pciture to help any further.
grumble ·
They are similar to the T1 box so if the bushes or worm aren't worn out giving axial play it should just be a matter of adjusting.
psimitar ·
grumble wrote:They are similar to the T1 box so if the bushes or worm aren't worn out giving axial play it should just be a matter of adjusting.
Worm bearing wear play can be reduced with the large locknut and grub screw. This one should always be checked before the roller is adjusted. 🙂
