WTB: Type 3 air vent drain box. 1969
https://forums.aussieveedubbers.com/threads/107836/wtb-type-3-air-vent-drain-box-1969
dreamland ·
I'm after the air vent drain box for a 69 Type 3. Does anyone know if they are interchangeable with later ones or which ones fit.
Mine is rusted out so need the complete unit
Call 0403 834 038
carbonmonoxide ·
Is that the rounded panel that sits inside the rear wings and vents into the flaps at the bottom of the engine bay on each side?
I need these as well. I cannot find anywhere that makes them.
dreamland ·
No. Should have been clearer. I'm looking for the none under the front cowl/ windscreen.
'69 Notch. I've seen and early 60's - no good. Seen 70's - wrong shape
Definitely need a 69 - perhaps 67 or 68. ?? I don't know as I would need to see them. Need the passenger side unit with airvent cables.
Any expert info or source greatly appreciated
adlbeetle66 ·
Post a pic please...
I think i have the right bit...
dreamland ·
Sorry for slow reply. Bit hard to see but the rusty mess is the vent. Passenger side.
Hope this helps
0403 834 038
adlbeetle66 ·
Is this the bit?
dreamland ·
Thanks for posting. Thats a different model.
adlbeetle66 ·
Either of these?
dreamland ·
Those look more like it. The light blue one in particular.
Can you send a pic of whats under the passenger side vent please. Thats what i need. The water catcher/ drain box.set up.
dreamland ·
White one could be the same as well. Looks like someone has welded over the vents on the blue one. perhaps it was leaking?
adlbeetle66 ·
Not sure... there is a plastic box that goes under each vent - this is not what you need?
dreamland ·
Thats what I need but mine was metal so they may be different - any chance of a pic of the passenger side ones?
adlbeetle66 ·
Have both now - will try to put pics on...
They have rust, but certainly not half as bad as what yours are 🙂
adlbeetle66 ·
Pics...
adlbeetle66 ·
Pics...
