I am wanting to buy Autocraft engine case for 101.6mm bore size. I will consider other brands. Used or new.
rhrnldi ·
i have the following parts....
Most are brand new and not used... have been on the shelf since the early 90's
Scat case 3 piece design New
910 pro series heads New
6 x 5"7" Carillo Rods resized by crankshaft eng. (used)
3 stage Autocraft oil pump and pressure relief (used but tested)
86.5 mm crank type 4 + porsche journal .. waiting for final grind. It is a raw early flanged scat forging... Final grind depends on use.. turbo or nat aspirated...
