Ok, so the transmission and engine are again attached to the chassis and I wanted to take it for a little joyride around the block. But I don't really know what I'm doing wrong to get it running.
First I attached a positive battery cable to the starter and a cable from the positive side of the starter to B+ on the regulator.
Then I attached the green wire from the distributer to the negative side of the coil and the blue wire from the positive side of the coil to the positive side of the battery.
Once I filled the float with petrol it fired right up using a screwdriver to jump the starter and ran for a few seconds. Then I decided to connect a jerry can and some fuel line so I can keep it running. However once I connected the fuel line to the jerry can I not get it to start again ( I am getting fuel now to the carb).
After cranking the engine for a while I noticed the coil became hot, I'm thinking it is the cause of the problem. I disconnected the middle plug off the distributer to see if it would spark off the fan shroud but nothing. Did I do something wrong to fry my coil?
Anyone got any ideas? I really want to take it for a short spin 馃お
m4co 路
