stuck tierod
https://forums.aussieveedubbers.com/threads/107957/stuck-tierod
jobie ·
Hi All,
I'm about to put a new front beam in my 56 beetle and therefore need to remove the old one.
I have taken out the tank, uncoupled the steering and loosened the bolts on the tie rods but they are fixed tight and will not budge even with a good wack with a hammer (as good as you can do inside a VW).
I need to get this apart by tomorrow arvo.
Anyone got any good ideas or a tool that could be borrowed (Melbournes East)?
Joel
Anthiron ·
They are a taper fit. You can use a tie rod fork or something like this
https://www.google.com.au/search?q=tie+rod+remover&biw=1920&bih=943&tbm=isch&imgil=m8IC_vFOvWfUFM%253A%253BSCNXY0FtmmPFTM%253Bhttp%25253A%25252F%25252Fwww.harborfreight.com%25252Ftie-rod-and-pitman-arm-puller-1752.html&source=iu&pf=m&fir=m8IC_vFOvWfUFM%253A%252CSCNXY0FtmmPFTM%252C_&usg=__wDBQRj72npFUb-ac2K3OpuXKAbg%3D&ved=0CEcQyjc&ei=_9OVVOShMMLZ8gWIsoKABg#facrc=_&imgdii=_&imgrc=m8IC_vFOvWfUFM%253A%3BSCNXY0FtmmPFTM%3Bhttp%253A%252F%252Fwww.harborfreight.com%252Fmedia%252Fcatalog%252Fproduct%252Fcache%252F1%252Fimage%252F9df78eab33525d08d6e5fb8d27136e95%252Fi%252Fm%252Fimage_18336.jpg%3Bhttp%253A%252F%252Fwww.harborfreight.com%252Ftie-rod-and-pitman-arm-puller-1752.html%3B1200%3B1200
jobie ·
Anyone have a tool that I can borrow / hire to do the job? I have smashed it with a hammer all afternoon from any angle I can could and no luck.
Joel
ian.mezz ·
jobie ·
Hi Ian,
I will give that a go tomorrow.
bugzla ·
ha I posted just last week the same thing I needed to press mine out
If you dont have tool you need to hit it with 2 hammers from apposing sides at the same time
kaiisons ·
jobie where are you located, i have the tool at home.
splitbus ·
Supercheap $15
