Aussieveedubbers 路 Tech Talk
Cylinder head cracks - where?
https://forums.aussieveedubbers.com/threads/108061/cylinder-head-cracks-where
torana 路
hi guys, couldnt find this on the site.
wondering where the common cracks occur in the cylinder heads?
about to build a type 3 1600 motor and would like to check.
Thank you
馃檪 Muz
cb john 路
The most common place for crack is between valve seats and / or between spark plug hole and one or both valve seats..
hus22l 路
As I understand it, cracks between valve seats can be tolerated but cracks between valve seat and spark plug hole are not good. Obviously no cracks is best! Good luck.
馃檪
dangerous 路
Don't forget to check inside of the exhaust port.
Between the seat and where the valve guide pokes into the port.
vduboy 路
dangerous wrote:Don't forget to check inside of the exhaust port.
Bloody hell they crack there too?? How many have you seen like that Dave? I went through half a dozen s/h heads for the bosses cheap K/g motor build and seen heaps of cracks as mentioned and just ended up buying new ones.. 馃檮
torana 路
thanks for the heads-up on where to find them guys, much appreciated 馃檪
