So I have got my daughters kombi running and registered but it hasn't been driven very far (around the block) and after changing a fuel pump the other night I noticed when giving the 1835 a good rev there seemed to be sparks shooting out of the alternator stand which frightened the crap out of me seeing as a bit of fuel was spilt on engine during the pump changeover.
The alternator is a bosch 55 amp unit that is pretty old but I threw it on the reco motor to replace the old generator. I doubt if I have the wiring wrong because its charging normally, but I wonder, if something was stuffed inside the alternator would it be possible for it to 'shoot current' through the body of the alternator and down the stand?
I had a type 3 fuel pump on it originally to get it running but noticed one night that the alternator and pump body were almost touching and because it was dark I noticed a spark jump across when revving. So I put on a new correct pump and now the sparks seamed to come from where the alternator stand bolts to the engine block. It only happens when you give it a good rev so it seems to be tied with engine speed.
Any advice would be greatly appreciated.
Thanks. Greg
grinderman ·
