Hi all,
I have consolidated all my sale posts into one to make it easier for you and me to see what is still for sale.
Please only contact Via e-mail or phone, do not pm me as I do not get on here very often any more and you pm may go unanswered for several weeks.
I am having a shed clearout and as I find items I will be posting it here. I am taking a step out of the VW scene and want the money and space for other things.
Items:
* CB front and rear disc brake kit to suit king and link pin beelte with dropped spindles and wide 5 stud pattern. These are new still in boxes, never unpacked, comes complete to lower and stop you early bug. Wide 5 brakes so you can still run stock steelies if you want or empi 5 spoke or others. 2.5" drop spindles are in the box as part of the kit and braided brake hoses too. These are for a short rear axle (pre'65). The only thing you would need is a new brake master cylinder and resivior if you desired. The pictures are taken from the CB website for your reference. These cost me over $2k to buy and I have never unpacked the boxes.
I am selling them as a set front and rear for $1400. If you would like to get the fronts only, sure you can but they will cost you $1100 and the rear set is $700. **** Sold ****
* Petronix billet dizzy, complete with ignitor II module ready to run. New still in box never run. I do also have a petronix ignitor II coil too hidden away.
Price $250 - **** Sold ****
*Amber light, Halogen style, you can replace the blown globe 12v. $50
*Hella Reverse Light Lens good, little bit of patina on the back of it. $100
*NOS 36hp Judson Supercharger and bottle. Ok I have been hanging onto this for the last 10 years and i was going to use this on my '59 but have never got around to it. Although it looks good in the display cabinet in the lounge room I am sure somebody could actually put it to good use. I was sold this off this forum 10 years ago as a NEW OLD STOCK judson supercharger for a 36hp engine, the person I bought it from stated the box had fallen apart so I do not have the box. It has never been installed on a engine and turns over as you would expect a brand new one to. I also have the marvel oiler that is also NOS but no glass bottle as it broke. again as it is NOS it has never been on a engine.
I am asking $1800 Firm for the pair, yes you can get second hand cheaper and yes you can get repro, but this is NOS. ****** Sold ******
*Beetle Interior, grey interior, door pannels, rear seat base and back, Honda Prelude front seats on VW runners. I would recomend replacing the drviers seat though, but you could still use the base and frame. the bases were designed to sit you a bit lower and further back than a stock seat. really comfy.
$100 *** Sold ****
* CB Maxi Filter Sump, It is a Mini sump with a filter in it. Washable element, has been used, here is the blurb from the CB web site: The new Maxi Filter Sump bolts right on, to filter oil 100% of the time. The new Maxi Filter has 168 sq. inches of filtration area. That's 25 times more than a stock VW oil screen. The Maxi Filter traps harmful metal and carbon particles before they reach the engine bearings. Your engine will run cleaner and cooler with a Full Flow Maxi Filter Sump. You can clean your filter as often as required to remove sludge and acid build up. Installation of the NEW Maxi Filter Sump is as easy as changing your oil. Just remove your stock oil plate and screen, then slip in the Maxi Filter and bolt on the mini sump. It's that easy... and you can install a Maxi Filter Sump on all 40hp, 13, 15, and 1600cc based engines, just bolt it on. A special one-way pressure relief valve assures continual flow of oil if the filter becomes clogged with sludge or goo. The pleated Micron Flow Filter Sump features a recessed oil drain plug and is tougher than a stock oil drain cover. It can take a beating and keep on filtering. Each Maxi Filter Sump Kit is shipped complete and ready to install with Filter Sump, filter, by-pass valve, gaskets, and seals.
Price $50 Back on Market
*Empi Breather Kit, includes valve covers, hoses, billet breather box, all fittings. never used.
Price $40
* Urathane Gearbox mounts, never used still in bag
Price $30
* Scat Billet sump with magnet drain plug
price $20
*Empi Full flow oil pump with filter. Rplaces existing oil pump and then you use a golf oil filter, it filter 100% of the oil, add to your oil capacity too.
Price $70
Details:
All items are located in Theodore ACT 2905
My name is Ian Bugden
Contact me on 0415 928 687 or thebugden@gmail.com
Ian Bugden ·
