blompod wrote:The release lever is the one on the gear box? and how do you adjust the pedal rake? because it is quite forward....
Pedal rake adjusted by the stop plate on the floor behind the clutch and brake pedal pivot. This should be adjusted first for how you like the pedals set.
Then you adjust both the brake pedal actuation rod and clutch pedal freeplay.
yes the release arm is on the passenger side of the gearbox. doing grumbles method means you don't have to keep get under the vehicle to make additional adjustments but you have to push against the arms spring force until you feel extra resistance of the clutch pressure plate so can be harder to do.
