Aussie ·
When running a larger diameter fuel line (8.0mm) in combination with a stock mechanical pump, will there be any negative effects on fuel pressure?
https://forums.aussieveedubbers.com/threads/108113/large-diameter-fuel-line-stock-pump
Aussie ·
modnrod ·
psimitar ·
Aussie ·
Yep for dual carbs. Will come out the pump on stock line and then flare up to 8.0mm before a pressure regulator (acting as t-piece) and then split off to each carb. Stock diameter line will be limited to short sections to and from pump, rest will be 8.0mm. Hoping to maximise volume from stock pump.psimitar wrote:For such a short pipe run to the carb I doubt it's notice unless you're running bigger carbs but then again for bigger carbs most upgrade to an electric pump for higher flow rates.
psimitar ·
fish26 ·
Aussie ·
That is what I am banking on, hence running a fuel reg to keep a check on pressure at higher RPM. Just hoping to get enough volume through......... this is not a race motor so do not think there should be a problem.Joel wrote:They usually put out too much rather than not enough.
