is there an easy way to separate the heads from the barrels when trying to pull a motor apart?
the heads seem to be bringing the barrels off at he same time as the head.
Muz
psimitar ·
piece of wood and a lump hammer to try and shock them apart. Sounds like you have rust and oxidation causing them the stick together.
Camo ·
Compressed air into spark plug hole, best if hose has screw in type on end of it. You could also use a lever under head, but be careful not to break barrel fins off.
vwo60 ·
I use a soft hammer tapping the exhaust studs only, Do not hit any other part of the head other wise you can bend of break a fin, If you use the compressed air method as above make sure you leave the nuts on a couple of head studs, just back them off several turns.
torana ·
OK....thanks for the suggestions everyone 🙂
will see how it goes
LUFTMEISTER ·
Go to bottom dc and 1/2 fill gap with grease. Refit plugs and turn over by hand. Leave on some loose nuts to catch head. All good. My2c
