does anyone know what model mercedes the big brake kit for syncos is off I need new disc rotors and I am finding very hard to match the disc I have on the van, its about 290 mm dia hat is about 48mm ..I think the brake kit was a Oettinger kit..
Use the Brembo online catalogue as you can search using disc dimensions instead of just looking for a manufacturer and model. Much more useful in cases such as yours.
PAZZAN ·
merc & audi are close but not the same,tried both catalogue dba & brembo no luck taking them down to dba office tomorrow at silverwater see what they can do 😵💫
psimitar ·
So using dimensions in the Brembo was a no go? Did you try just using the diameter and width only so as to maximise findings?
psimitar ·
PAZZAN ·
YEP DBA said mitsubishi evo 294mm😵💫 x 24mm are the closest to the specs so might try them just drill 112 pcd for vw 😵
