LED Lights
https://forums.aussieveedubbers.com/threads/108228/led-lights
Craig S ·
Hi All,
Decided to change to LED lights in the hope they'd be brighter and draw less power. The brake and reverse lights work brilliantly, but I'm having dramas with the indicators.
Here's what I've tried so far.
1. Replace one globe and the indicators flash much faster (no surprise there).
2. Replace both globes and only one of the individual LEDs light up in each globe.
So I decided to replace the flasher relay with an LED specific one. Admittedly it's a relatively cheap one from Ebay. I've tried it all combinations with both the LED globes and normal globes and absolutely nothing happens. I'm guessing that the relay is a dud.
But, before I go out and buy another relay, I thought I'd ask if there were any other ideas of what I should try.
Car is an LBug/1303 so the relay sits behind the fuses under the dashboard. The relay was in the first position, whilst the Bentleys says it should be in position 3 (again not a big surprise).
Craig
Maybe the new relay has a different wiring configuration?
ian.mezz ·
I think it cause they use less power allowing them to flash faster, just like in a newer car when one globes blows the blinkers flash faster on the side that the globes blown .
As Steve said its probably the terminal layout is wrong, I know when I fitted my LED flasher it was the wrong way around for VWs, i had to switch the wires around in fuse box.
Apparently most Jap cars are the other way around to Euros.
If your relay is this layout its the wrong one, VWs need positive on the right.
vlad01 ·
ian.mezz wrote:I think it cause they use less power allowing them to flash faster, just like in a newer car when one globes blows the blinkers flash faster on the side that the globes blown .
yes flasher cans are load dependent for timing. LEDs have 100s x less load than conventional lamps.
You can get electronic flasher cans that don't rely on load and are designed for LEDs
vwo60 ·
you can also fit a dummy load and use the standard flasher can. http://www.ebay.com.au/itm/LED-LOAD-RESISTORS-FOR-VEHICLES-NOT-LED-COMPATIBLE-QUALITY-FROM-LED-AUSTRALIA-/281562432030?pt=AU_product_Trailer_Parts&hash=item418e6dc21e#ht_552wt_1124
psimitar ·
If you have the old bulb and it ain't blown then measure it's resistance. Then buy a 1/2W resistor slightly lower than the bulbs resistance and wire it in parallel to the LED bulb. This should pull the overall load down to where the relay flashes much closer to the original time period. 🙂
AA003 ·
The bulbs resistance needs to be measured when the globe is hot as globes have a positive temperature coefficient and the resistance varies greatly with temperature. Better to use ohm's law. The resistor that you will need is 36 watts as it is replacing two 18 watt globes.
Much easier to buy a dummy load as vwo60 said.
psimitar ·
Better for heat dissipation to wire the resistor at each bulb and not just one resistor for each side.
1/2W should be fine, of I've remembered my degree tech labs properly, but 1W to be safer as due to the flashing nature of the indicator the resistor isn't having to dissipate as much heat.
The resistor method is just a neater solution than trying to wire the additional ordinary style bulbs in parallel with the LED ones.
Least the OP has a few options to try now 🙂
AA003 ·
psimitar wrote:1/2W should be fine,
.......and carry a fire extinguisher.
vwo60 ·
The inline resistor is a no brainer and available over the counter, use the kiss principal.
modnrod ·
The extra resistor will also mean that the total current draw on the electrics will be the same as if you were using a normal bulb as well.
I agree with the KISS principle.......
psimitar ·
Love how friendly this forum is lately. Have you ever stopped to think that someone has been doing this for a while and has a bloody electronics degree and therefore has some idea of what they're doing.
Stop being such an arse 🙅
vlad01 ·
AA003 wrote:The bulbs resistance needs to be measured when the globe is hot as globes have a positive temperature coefficient and the resistance varies greatly with temperature. Better to use ohm's law. The resistor that you will need is 36 watts as it is replacing two 18 watt globes.
18w??
last I looked 21W is the standard globe for indicators and brakes lights and such.
AA003 ·
vlad01 wrote:18w??
Yes I think that you may be correct but it would be close enough.
It's a lot more than some jerk saying that 1 watt is enough that doesn't have a clue.
6 volt were 18w is probaby what you were thinking of.
psimitar ·
AA003 wrote:It's a lot more than some jerk saying that 1 watt is enough that doesn't have a clue.
You truly are an A-hole sir. I don't lend my advice unless it is something that I know about. Maybe if you go and integrate the power of the tapered square wave of the indicator time period to calculate the heat build up in the resistor then I'll happily eat humble pie but in the meantime you should learn to be a more open minded individual and if you think someone is in error when they write something then inform them of their mistake in a more polite and informed manner with technical reasoning instead of being so damned rude.
AA003 ·
Craig,
The problem with using LEDs is that the original flasher relays relied on the current of the globes to make them flash. As LEDs are very efficient and use only a tiny amount of power the current is not enough to make them flash correctly.
Craig you have four options.
1/ Use an LED flasher unit and mount it in the fuse panel and change the connections. The connectors in the fuse panel can be released by pushing a small jeweler's screwdriver down the back of the lug to release it.
2/ Use an LED flasher unit and mount it remotely using a short loom with male connectors for the fuse panel socket end and female connectors to the relay.
3/ Use a load resistor that is commercially available for this purpose.
4/ Use a load resistor that you obtain yourself and wire it in parrallel with the LEDs.
To select a suitable load resistor you will need to calculate the resistance using Ohm's law.
You already know that the nominal voltage is 12 volts and the globes are 21 watts each.
To calculate the current you can divide the wattage by the voltage and the multiply by 2 as they are connected in parrallel.
21/12 x 2 = 3.5 amps.
Ohm's law is R=V/I R = 12/3.5 which equals 3.4 ohms.
To calculate the wattage of the resistor you will need to multiply the voltage by the current which is 12V x 3.5A = 42 Watts
So you will need a 3.4 ohm 42 watt resistor.
psimitar ·
Thank you 🙂
The maths is correct for a constant load but I had LED bulbs back at Uni some 12yrs ago and did the calculations then and was able to get away with 1W resistors. Could of been 5W but pretty sure 1 was enough per bulb and worked happily until I sold the Bug a year or so later 🙂
hulbyw ·
Craig, you can buy resistors at Repco specifically made for fitting LED indicators. It is a common practice on utes and 4by's to change at least the rear light clusters to LED and Narva make a specific resistor to suit. Probably an expensive way to do it, but easy as.
vlad01 ·
psimitar wrote:Thank you 🙂
there is theory and there is practice.
In theory 42w sounds to be correct amusing the flasher needs all the load the lamps produce which all calculations are based on.
However the flasher in theory (if taken apart and circuit reverse engineered to derive all values for calculation) may only in reality require a the said small load.
In practice it obviously works. 👍
its like a theoretical assumption that a type 3 6v fuel gauge will fry in 12v system (calculated to be 4 x the original wattage) works perfect in practice with years of no trouble for many people I know.
psimitar ·
Indeed 🙂
As for a light bulb, the wattage not only relates to the power drawn but also to the light emitted. Being as you're a electronics guy too then you are quite right that the actual load the circuitry sees is far less than the stated load.
Your 6v fuel gauge should work fine at 12v so long as the wire for the electro magnet windings inside the gauge can handle the extra current. Above that the device will electrically work in the exact same fashion 🙂
