WTB Kombi Rims 5x112 Bay Window
https://forums.aussieveedubbers.com/threads/108274/wtb-kombi-rims-5x112-bay-window
Ted2 ·
Hi,
I'm chasing a set of standard late bay kombi rims (5x112). Preferably 5 in total and in good condition.
Preferably around Canberra or Sydney.
John
Luckyphil ·
Check these out and only $70 or offer http://www.gumtree.com.au/s-ad/tascott/wheels-tyres-rims/wheels-to-suit-vw-kombi-t3-5-stud-112mm-spacing-55mm-offset/1063519459
77dual ·
Different offset on those T3 ones in the link, 55 instead of 38, should still fit though. You could also try Nick out at Volksparts in Bungendore.
Ted2 ·
77dual wrote:Different offset on those T3 ones in the link, 55 instead of 38, should still fit though. You could also try Nick out at Volksparts in Bungendore.
Thanks for the heads up guys. Rims are destined for a splitty running 68 ball joint front beam and straight axle in the rear (all 5x112). I know the standard kombi rim offset fits fine. Any views as to whether the T3 offset will fit?
grumble ·
If you don't do any good I have a set of bay window wheels in Taree,ring me for more info if needed.0408 025 845.
Cheers Les
Special Air Service ·
I think you'll find that the T3 and bay window do actually have the same offset. I'd say the seller is mistaken here.
Ted2 ·
grumble wrote:If you don't do any good I have a set of bay window wheels in Taree,ring me for more info if needed.0408 025 845.
Cheers Les
Thanks Les. I've found a set closer to home. Will be in contact should that lead fall through.
Scottkombi ·
Yes the T3 & bay kombi rims are exactly the same wheel.
I used to interchange them - syncro rims are even the same off-set - just slightly wider @ 6" rather than 5 1/2" wide but the standard T3 wheels fitted identical on my 71 and previous 73 bays.
binner ·
Hey mate , what is your budget? I have 4 standards that were blasted and powder coated black with Yokohama A drive 195/70/14 91 H Tyres at proll 95 % tread left. All rims and tyres are in sweet condition. Just bolt em on.....
I'm thinking about going some mags so genuine reason for selling.
PM or call me if you are keen
0404874097
