Wanted Gearbox
https://forums.aussieveedubbers.com/threads/108293/wanted-gearbox
robw914 ·
I am after a swingaxle gearbox from a late 1300 Beetle 1974 - 1976 Serial number will have AT or AS prefix.and it will have the tube for the release bearing.
Please contact Rob on 0417 247 424 or PM. I am in Melbourne.
Thanks.
ciarog9 ·
I think AS and AT are IRS gearboxes.
robw914 ·
I want it for a 1968 beetle which has a 2 litre type 4 motor (upright conversion). I am after the 3.875 diff ratio, so called "freeway flier" gearing, but I am retaining the swing axles. The clutch needs the tube guide for the release bearing. Any info gratefully received. Thanks. Rob.
ragged ·
Hi Rob,
The 1300 late swinger has a 4.375 diff (ring and pinion).
The 3.875 diff was only available with the Type , 1 late '73 on IRS boxes.
What you will need is a 3.875 ring and pinion fitted to a swing axle box.
Dave
Performance Upholstery ·
You can buy the 3.88 ring and pinion new if you can afford it...
http://rodpenroseracing.com.au/177-diff-parts
splitbus ·
TRANSMISSION CODES
AA 1200 4.375 from chassis No 0 981 810
AB 1300 4.375 Up to 8/70
AC 1500 4.125 Also some 1300 from 8/70
AD 1200 4.375 Limited Slip Differential (LSD)
AE 1300 4.375 Limited Slip Differential (LSD)
AF 1500 4.125 LSD up to 8/70; also some 1300 from 8/70
AG 1200 4.375 Type 147 (Fridolin)
AH 1500 4.125 IRS suspension from 8/68
AH 1600 4.125 8/69-8/72
AK 1500 3.875 Type 181 Trekker up to 8/70
AK 1600 3.875 Type 181 Trekker from 8/70
AL 1500 3.875 Type 181 with LSD to 8/70
AL 1600 3.875 Type 181 with LSD from 8/70
AM 1300 4.375 Saloon and Cabrio from 8/70
AN 1600 3.875 Karmann Ghia IRS from 8/70
AO 1600 3.875 Karmann Ghia from 8/70
AP 1300 4.375 LSD from 8/70
AQ 1600 4.125 LSD 8/70-8/72
AR 1600 3.875 K-Ghia LSD from 8/70
AS 1600 3.875 Type 1 from 8/72
AT 1600 3.875 1303S and Cabrio from 8/72
AU 1600 3.875 Ditto with LSD
BA 1300 4.375 Semi-auto from 8/68-8/70
BA 1500 4.375 Semi-auto from 8/68-8/70
BC 1300 4.375 Ditto with LSD
BC 1500 4.375 Ditto with LSD
BE 1600 4.125 Semi-auto from 8/70-8/71
BF 1600 4.125 Ditto with LSD
BG 1300 4.125 K-Ghia semi-auto from 8/70
BH 1300 4.125 Ditto with LSD
BJ 1300 4.375 Semi-auto from 8/70
BK 1300 4.375 Ditto with LSD
DA 1500 4.125 Type 3 swing-axle to 8/68*
DA 1600 4.125 Type 3 swing-axle to 8/68*
DB 1500 4.125 Ditto with LSD*
DB 1600 4.125 Ditto with LSD*
DC 1500 4.125 Type 3 with IRS from 8/68
DC 1600 4.125 Type 3 with IRS from 8/68
DD 1500 4.125 Ditto with LSD
DD 1600 4.125 Ditto with LSD
robw914 ·
Many thanks to everyone for their help. As usual Aussieveedubbers a wealth of knowledge. Has anyone got a good late 1300 swing axle gearbox with clutch release bearing tube for sale?
