I'm after a carby I can just bolt on to my Baja to get it running and registered while I sort out the finer points of adapting the Holley. I've got the standard manifold fitted so just need maybe a 34 PICT or something similar.
Cheers, Sean
Corlette NSW
0431 644 440
pfillery ·
Got a 28pci carb but is probably off an older motor.
Sbug 71 ·
Hi pfillery. Thanks for your reply. Does it make a difference if it is off an older motor?
Cheers.
kombie200 ·
Sean
I have a 30pcit if you want it, I am located at Williamtown NSW
Trendy ·
I have a 34 pict 3 carb off an engine. Has a new diaphragm kit in it but I never refitted it back to engine. I bought a new out of the box one to replace it. Probably needs a fine tune after bolting it to engine and starting. I am no mechanic but it should be good. It's a solex if your interested? It was running in the beetle I have been working on over the years.
