guys I have 2 15 inch standard wheels for a bug at home however they are different offset what the hell, does anybody know how I can figure out what they may be off, they do have one letter stamps on them if that helps
stevo
MR930 ·
Maybe 1 is off a type 3.
adlbeetle66 ·
When the tyres are off there are normally markings on the inside of the rim..
vlad01 ·
there were many different offsets for standard wheels over the years and models.
type 3 used as far as I know across production 4.5" x 15, ET 45mm. that is for all 4 stud type 3.
beetles had many offsets, normally much less than type 3. I don't know the numbers though as i don't have a beetle.
bugzla ·
when you look down on one the centre hub is in line with the outer rim while the other has more lip
Ampdub ·
Is there some kind of cross reference chart someone has tucked away?
Calcool ·
68 and 69 Beetles had 4 inch rims and Beetles from then on had 4 1/2 inch rims 68 onwards Type 3 were all 4 1/2 inch all 4 x 130 PCD
