Hi all, patient is a 60 Beetle, unmodified.
Car has recently had a lot of mechanical work including brake work, such as cleaning up the master cylinder, full bleed, and clean of the reservoir. Has driven less than 100 k's and been laid up due to other issues (non-related to brakes). Car hasn't moved for weeks and on Thursday I found a puddle under the car of brake fluid, dripping quickly. Investigation showed the fluid has come out of the top rubber plug where the reservoir tube comes in to the top of the master cylinder.
The plug doesn't seem to fit right, just loosely sitting on top. I am told they just clip in without much force, I thought they would have to sit fairly firm as they would hold pressure of the fluid in the master cylinder?
I know I am up for a brake bleed now once I get the plug to hold. Is it as simple as getting a new plug to just sit in the receptacle? I really would have thought it would need some degree of tight fit to hold there.
Not sure why this one popped after not moving for weeks, any ideas?
Thanks.
phantom ·
