helbus wrote:What carbs are fitted to a 1776 Type 1 engine build.......... Smooth torque required. Is there a matching cam and .........?
The difference between a set of twin Weber IDF style carbs, and a stock 1600 TP manifold with a Solex 34PICT3 is about 10% or so. The more you want to rev the thing, it is possible that a stock Solex can be up to 20% down in power, but only when the revs go north of 6000-6500. It's your decision whether the expense is worth it for your application. Twin IDFs make more torque everywhere, but have 4 pilot jets (which are sensitive to dust, use good filters), 4 main jets, 4 emulsions, etc. Solex 34s aren't perfect by any means, but are stone-age simple and do the job fine, for a 1776 I would throw in a 28mm venturi and just drive it. You'd be surprised though, at just how little difference there is between the two under 3000. Same with exhausts, quite often non-merge systems can make more torque under 3500 than the almighty 4-1.
Cam specs are usually related to the rev range, but more importantly, the torque peak/curve, and what makes the difference is the overlap and duration.
If you run twin IDFs you can get away with more duration without the idle being affected much, but you will still lose torque on the bottom.
If you want peak torque around 3000, but also lots of torque under this mark (like if you have a Kombi, or if you are towing a trailer up hills all day), then keeping the cam close to CB "cheater" specs, or W100 or smaller will do fine, even a Web 218/119. If you have a Beetle, and you want to spin it up a bit to 6000 or so occasionally, W110 or Web163 or Web86B will make it rev a bit, but you will be down on torque at the wheels under 3000.
There you go! One more unsolicited opinion!
