Aussieveedubbers · Bugs
Fitting clutch cable
https://forums.aussieveedubbers.com/threads/108471/fitting-clutch-cable
thepie ·
Hi all , just removed pedal cluster to paint floor pan and having a nightmare trying to get it back to together , is there a easy way to get to keep clutch cable on ? It keeps falling off , also should there be a wing nut on other end?
Cheers Dave
RestoKäfer ·
drill a little hole in the hook and use a split pin ,
You keep the cable on the pedal hook by not allowing the pedal to fall rearward, keeping it upright or fwd only it will stay on the hook.
Yes, a wing nut is usually fitted, although factory fittment was a pair of jamb nuts, 14 and 11mm spanner hex
Old Dubber ·
My trick is to use a thick rubber band to keep the cable on the pedal hook. The pedal can flop around while you get the nuts/wingnut on down the back.
RestoKäfer ·
How did you go,
