HD Gear-Box Mounts
https://forums.aussieveedubbers.com/threads/108504/hd-gear-box-mounts
DreamWeaver ·
Interested in hearing some feedback/experiences - As I am looking do what has already been done in the following link: http://www.volksbolts.com/faq/gearbox-rear.htm
Similar to the above, I already have the CB rhino mounts - what I am look to achieve is to simply replacing the factory original cradle (that fits to the frame horns and holds the trans from the bottom) with the HD empi bottom mount - NOT THE STRAP, similar to the link above, to help support a bigger motor and new trans.
Simply speaking what I want to do is - retain my CB Rhino mounts & use the bottom of the empi HD trans mount; my question is: will the empi HD mount give me grief?
The reason for these specific parts to be used and not more full on tech is because it isn't a drag car and its pretty low, so I figure I can replace what is nackked, support the new set up and retain most of the ground clearance, and retain drive quality.
Ideally; ground clearance similar to the bellow image (although the image has a solid mount set up - no padding- from my research the ground clearance should be the same)
Your constructive feedback is welcomed
Thanks Dubbers
vwo60 ·
I bought my front mount mount from vee force racing, weld in mount takes a bit of time to fit but worth it.
karmann141 ·
Nice clean undercarriage vwo60- good to see you cleaned up the oil leaks for the photo😂
any EMPI item will give you grief
DreamWeaver ·
vw54 wrote:will the empi HD mount give me grief
Nice one, this is true
DreamWeaver ·
vwo60 wrote:I bought my front mount mount from vee force racing, weld in mount takes a bit of time to fit but worth it.
Thanks for the pic, I looked in to this mod, ACN have a bolt in version however the concern I have is ground clearance.
Sitting just before the rear wheels it vulnerable to scrapeage.
vwo60 ·
Sway bar is lower and there has never been any issues with hitting anything, if your car is that low then you will have a problem, the bolt on mount from ACN does only half the job.
