Hi , just took out klippan seat belt out while I painted floor , come to put back and it's stuck , won't release ,does anyone know how to release these ? Any help would be great
AA003 ·
It needs to be at the correct angle or it will lock.
It needs to be at the loose or it will lock.
thepie ·
Ye I've tried that , it looks like you can do somethink on the side once you move the plastic tab , ???
thepie ·
Anyone ???????
You will need to have it on the correct angle. Then force just a little bit more belt to wind in, until the lock mechanism is released by the inwards motion of the belt. Then it will come out again.
grumble ·
The easiest way is to mount the belt in the vice with the belt in a vertical position,as helbus says force the spool to take more belt and then carefully pull the belt upwards then clip it with a peg so it doesn't retract again.
