Fuel gauge wiring... Help!
https://forums.aussieveedubbers.com/threads/108569/fuel-gauge-wiring-help
danza85 ·
Hey, so I got a gauge for my 61 bug, didn't have one. Has sender unit, now just need to know what goes where..
Has...
+ power, constant or switchable?
G.. ?
Earth symbol - sender unit?
Please help!
grumble ·
+ is power from the ignition,connect this to the fuse box the other wire goes to the terminal on the sender unit and there will be a wire from one of the screws on the sender which goes to one of the tank mounting bolts to complete the circuit.
psimitar ·
The gauge body itself also needs a good ground or the gauge won't read correctly. Hence why there's the earth symbol on the housings stud.
roofchop ·
Are you still 6 V or 12?
Dave
danza85 ·
Thanks guys.
It's 6v gauge, 12v system..
psimitar ·
danza85 wrote:Thanks guys.
You can fit a voltage regulator if you wish to ensure you have no problems with the gauge but I've heard many run them as is on 12v without a problem. Maybe the magnetic windings can handle the extra current but the choice is yours. Voltage reg is less than a fiver 🙂
