Hey guys,
I spend the last 2 and a half years to build a 2.5 Liter Subaru Beetle (check out my build thread (work in progress)) and I might say, that we are on the finish line by now...
Not everyting is fine with this beetle, I have some ECU problem that prevents the engine to run properly above 2500 RPM.
I hope you have some hints on how to fix it, because I am slowly running out of ideas.
But first of all the details:
The engine is a EJ25 2.5 Liter SOHC engine from a 2000 Subaru Legacy with 156 hp (Phase 2).
When I fire it up, it starts with a relatively high idle but then quickly goes down to a smooth idel at around 800 RPM.
When I start to open the throttle a bit, the engine starts to rev up slowly as one would expect.
As soon as it reaches 2500 RPM, it starts to run very rough and drops down to idle and rev up again and again (with no change on the throttle, still slightly open)
When driving the car, the behaviour is the same in every gear.
As soon as the engine reaches 2500, it stops accelerating (again with no change on the gas). Then suddenly after it dropped to 1800'ish, the acceleration kicks in again...
I also had some high revs when rolling in idle, but I fixed that by grounding the //Edit: Neutral //switch (B135 Pin 26 at the ECU)
Error Code says 24, but I cleaned and checked the IACV and it seems to work....
Any ideas?
Thanks in advance...
Chr_ ·
