Aussieveedubbers · New Members Forum
Knocking steering box
https://forums.aussieveedubbers.com/threads/108589/knocking-steering-box
stevef ·
Hi all. Can anyone help? I have just bought a 72 low light kombi that needs a bit of TLC and I have a clicking noise from the steering box. I have adjusted the play out of it but there is still a click when you start to turn. Does anyone know if there is there any quick fix or recon kit that is available to get this through a roadworthy? Any suggestions appreciated. Cheers
donn ·
Best suggestion is to ask in the "tech talk " section.
Grey 57 ·
Check for play in ball joints and pivot pin. Might also be play in the bush that's in the steering box where the pitman arm attaches. If the pit arm moves up and down slightly when you turn the steering wheel, this is (one) of the potential causes. You can't adjust for this wear.
stevef ·
Thanks guys I will check this out. Cheers
