Disk brakes
https://forums.aussieveedubbers.com/threads/108684/disk-brakes
IN THE WEEDS ·
Where is the best place in sydney to purchase front and rear disk brakes for my 64 beetle.
rickp ·
you can try your luck with classic at rydalmere... but only if you drive there, and hes open, and he has them in stock. dont wait the famous 2 weeks for him to get them in... because you could be waiting a lifetime
Vollks will have them on the website and will most likely get them delivered to you in about 2 days. Vollks.com.au
newghia ·
Or order off Cip1, they are pretty quick with their deliveries
DON T buy EMPI brand nothing but trouble
landfall ·
Fitted EMPI rear discs to mine recently, easiest job I have ever done.
Everything fitted without a hitch and they work as they should.
Biggest problem I had was bleeding them, in the end I made a pressure bleeder using a Hills garden spray unit with a small pressure gauge screwed into the top, 8psi and before I knew it had a pedal equivalent to my modern VW.
This continuous EMPI bashing gets a bit monotonous, while some of there products may not be that great, bashing the complete product range and brand is like saying all footballers are criminals and drug takers, etc.
vwo60 ·
A lot of Empi products are just rebadged parts made by many manufacturers, I have found some of there gear very well made and other parts junk, another consideration would be engineering the brakes to comply, a lot of brakes bought into Australia will never comply because they do not use propiority parts that were complied in Australia originally or the importer never bothered to have them complied leaving the purchaser to do this at there expense. Give due consideration to have a set that are legal in this country so you can insure and register your car legally.
LUFTMEISTER ·
Seems overseas brakes don't work properly in Australia!!!, even though hundreds of these kits are sold all over this planet, with out any issues OR it could be a closed shop insurance /engineers cash cow being milked for all its worth. You decide my friend. My2c
IN THE WEEDS ·
Has anyone used the brakes from classicveedub or vollks. What are your thoughts on these are they worth the money
bevelhead ·
http://www.volksconversions.com.au/brakes.html
adlbeetle66 ·
Have heard some bad reports from Volksconversions, and vollks are EMPI.
PAZZAN ·
I have empi on the back of my sharpbuilt buggy 3 years no problems and passed by my engineer👍
grinderman ·
Have volksconversions front disc brake kit on my 69 bay and it has transformed the braking and will get a rear kit one day as well.
karmann141 ·
I know this is off topic - Barls can you please explain rules on naming and shaming one supplier and not another.
barls ·
ive removed my post thanks for reminding me. drunken moment
if anyone want to know of my personal experience with volkconversions pm me.
vwo60 ·
The buck stops with the owner of the vehicle as far as its legality, Liftmiester the purpose of the engineering is to ensure the vehicle is safe so you do not injure of kill other road user's or yourself. This allow 's you register your car legally so you can also insure it, If you are happy to drive a car that is non engineered then the owner of the vehicle will have to wear the outcome if there is an accident, Just like the guy in Perth who killed his child and is now in Jail. I will await the usual responses.
barls ·
lets keep this on topic and not take this in to a legality discussion again.
LUFTMEISTER ·
Usual rubbish example used to back up his argument. The guy in jailed welded 2 moving parts together, he was a knob and justice was forthcoming. He did not fit a part from overseas supplier that is in safe use around the world by other vw enthusiasts. The ADR is a closed shop tax on motor enthusiasts in this country, eagerly supported by the vehicle manufactures, engineers & the insurance industry. It will get to point were you will not be able to fit ANY parts to a car unless it comes from the cars manufacturer thanks to these lobby groups and lay down people who support them. They are just boiling the frog & you just don't know it. My2c
barls ·
thats enough anymore on the legalities and ill delete the posts. its off topic and I'm not letting you both turn this one in to another shit slinging match.
adlbeetle66 ·
So Chris, did you get your answer?
IN THE WEEDS ·
Lol. Are you able to register your car with the classic vee dub ones. Or would it have to be engineered and if so is it possible with these particular brakes
barls ·
you need to speak to the engineer and see if he's happy sign off on it.
it will need to be engineered under the new laws.
IN THE WEEDS ·
Ok so who knows an engineer in sydney
PAZZAN ·
http://vmcengineering.com/
I've also had a good run with Volksconversions rear discs, theyve been on my car for over 100,000kms, my yearly pink slip brake test results are on a par with my modern cars and engineering wasnt a hassle as its just OEM Porsche 914 discs and Fiat Spider Calipers.
On the subject of Empi discs though this happened to a set on a guys bug a few days ago on one of the facebook groups I'm on.
vduboy ·
I've got the Empi ones on the back of my buggy, they are the ones that use the heavier cast bracket and the Ford Taurus calipers, think they are a Varga brand, they passed the brake test well, in fact I had to fit a proportioning valve as they locked up just before the fronts.
I have used the Shermann kit before and the pads were always a loose fit in the bracket and gave a really annoying click click noise when the wheel was spun. Both kits have lousy handbrake cables, will be getting stronger ones made when they break, Also in both kits the cables were too long.
Have you looked into Todd's Subabrakes? He does all sorts of stud patterns too. Wish i'd have gone down that path would have made wheel selection a lot easier.
vduboy ·
Joel wrote:I've also had a good run with Volksconversions rear discs, theyve been on my car for over 100,000kms, my yearly pink slip brake test results are on a par with my modern cars and engineering wasnt a hassle as its just OEM Porsche 914 discs and Fiat Spider Calipers.
That is a bit of a worry.. was he doing anything out of the ordinary?? Jumping gutters?? WOW
bugmaniaar ·
Pop goes the can of worms....
I have front empi with drop spindles and have had no issues....like Forrst Gump said thats all i have to say about that.....
hus22l ·
Vmc engineering appears to be ACT not NSW. ?
AA003 ·
bugmaniaar wrote:....like Forrst Gump said thats all i have to say about that.....
Does he do the design work foer Empi?
Empi fronts are usually fine as they just use Varga discs and calipers, just replace the shitty chinese bearings they supply with the kit and you're laughing.
vduboy wrote:That is a bit of a worry.. was he doing anything out of the ordinary?? Jumping gutters?? WOW
He was just driving and reckons they cant handle any torque more than a stock engine.
vduboy ·
Joel wrote:Empi fronts are usually fine as they just use Varga discs and calipers, just replace the shitty chinese bearings they supply with the kit and you're laughing.
Wow, does anyone know what discs Shermann uses? I had them on my old one, used to drop the clutch full revs all the time with my old 1916 base like a stupid teenager, only thing I ever broke was the ring and pinion..! After 40000k's Hoping these discs will be ok.
If they were the same kit of his that I've got its Porsche 914 rotors and discs and Fiat Spider Calipers.
He uses some other calipers now, not sure what though.
vduboy ·
Joel wrote:If they were the same kit of his that I've got its Porsche 914 rotors and discs and Fiat Spider Calipers.
Separate hub/disc? Maybe thats what it was..
zayus ·
Hey hey,
Rear disc brakes...
I am not an engineer, and I'm a very limited back yard mechanic.
I have researched rear disc brakes.
Is your car swing axle and lowered?
Yes....
I understand that due to negative camber, after market rear disc brakes are a pain in arse to set up so that they work.
Try and find a set of Type 3 drums, if your car is a lowered swinger.
I'm sure there are members of our forum who can explain why rear discs on a lowerd swinger are difficult to set up.
Zayus
