Alternator to crank pulley offset
https://forums.aussieveedubbers.com/threads/108691/alternator-to-crank-pulley-offset
bowser ·
new to bugs so go easy.
currently doing a 12V conversion to my 66 bug, purchased a 95 Amp and brackets, mounted them up and confirmed both the fan assembly is assembled correctly and the alt is pushed back as far as it physically can and the pulley offset if setill way out.
do i need a need pulley or a crank spacer of something?
thanks
You need a 12 volt pulley. The one for the six volt has a different offset, but I guess you can see that
