The brake lights are on on my daughters beetle, they won't go off. Just pulled the wires off the master cylinder and they still stay on. Any idea where I should start looking?
I think it works the other way?
Short the wires you pulled off together and the light should go out
AA003 ·
No it doesn't.
AA003 ·
Are they only on when the ignition is on?
They should only come on with the ignition on and if you touch the 2 wires together.
If they are staying on without the wires touching or connected then its probably a bad ground causing feedback or the 2 brake light wires down to the master cylinder switch are worn through and touching each other in the loom somewhere.
MR930 ·
Thanks, looks like I best look at the earths. Yes they only work with the ignition on, and when I connect them at the master cylinder they stay on still, only one wire is live here thou.
MR930 ·
Ok all fixed, turned out to be the front plug on the master cylinder that's not hooked up, not sure how I only had power to one wire when I checked, must have been a dodgy earth on the test light.
