I am going to be running with my nose about 50mm off the ground.....
Stoopid maybe but I am.
Airbags not an option for many reasons including $$$$
It has dawned on me that gutters etc are going to be an issue, so looking at air shocks just to lift the nose when needed.
Cheap ones for load leveling aplications in the US, a bit bulky, but will probably do the job. (who needs steering lock anyway?)
Anyone using them?
Also seen Monroe ones in Oz for Statesmans...
Any info is good info, maybe.....
Dave
grumble ·
If you check the RMS regulations minimum clearance is 100mm but do as you will.
psimitar ·
Check out Volkszone.com as plenty of air ride threads in the UK plus the stockists there are cheaper due to more demand. Even good secondhand ones come up regularly on UK forums and Ebay.
Dude used some cheap ones from a tipper truck, i think, recently.
There's hydraulic too. Check it out maybe. Slower reaction to raise and lower compared to air but meant to be a smoother ride than air from what I've read.
I have K & L so eye to eye but what model number is best?
Which ones are you using Empi? (also torsion leaves in or out?)
The Samba link has fried my head!
Dave
empi ·
Torsion leaves in, i have ball joint, used Ma 756 but had issues with them hitting trailing upper arm, apparently there are thinner shocks available now for this application (not sure of part number.)
bugzla ·
if any one has the number for the thinner one let me know
tweety ·
Hi Roofchop.
Some informative answers there.
For what tis worth I have a fair bit of experience with air shocks and airbags.
Air shocks, amily the Munroe ones used to be the rage in the 1970's. Used often to raise a sagging tail when towing. Trouble was many shocker mounts dented or broke. Such shock mounts werent meant to take the pounding of a hard air shock.
Fasttrack to the new millenium and my trike. Panther trikes come with the smallest Boss airbags. The one advantage is that when towing the camber can be controlled as the fabricated swing arms travel in an arc. However they are still hard. Lower them too much and they dont do the job of which they were designed for. ...suspension!! a catch 22. They have gas shockers too and from what I've read oil shockers are more suited to airbags. Finally airbags only begin to work when a load of 200 kgms or so is placed on them. Got a light front end of a beetle and you might regret it. But by all means investigate it with these things in mind.
I cant see the purpose of going down to 50mm. The cops will get you as soon as they see the sparks. Then its more expence making it legal again. There has been many pics of my trike on these pages and its won several awards including international. I took the view that to look amazing (and legal) was more impiortant to me than being illegal and paying the price.
Its up to you but your machine could look fantastic and still be legal. That way the pri....ks wont get you. haha.
roofchop ·
All good.....
Maybe 50 mm is too low!
The current crop of air shocks are load assist ones from the US being repurposed by us lot!
They are a "regular" shock with an air canister around the body, so with no air pressure they work as a normal shock absorber, air them up and ride height on our featherweight noses comes up! Cheap and simple!
I have dropped spindles and adjusters so I can wind up the adjusters then gas up when needed.
