electronic ignition options
https://forums.aussieveedubbers.com/threads/108904/electronic-ignition-options
chrissys beetle ·
I suppose its been asked before
but I have a 71 beetle with a problem with idle and accelartion
Im wanting to go with electronic ignition
Whats the best ome to get
Im really keen to sort out my problem
when the engine is hot is misses and farts and if you stop the engine you have to wait till its cool to start up
barls ·
sounds more like vapour lock is one of your issues. theres more than one problem there.
psimitar ·
Yea, more than just the ignition causing your problems.
Idle problem could be air leak in the inlet or exhaust systems, incorrect timing, worn dizzy, worn and/or incorrectly set carb and that's off top of me head.
Hard starting when warm could first be the engine getting to hot in the first place and that could be wrong timing, incorrect carb settings etc. It could also be the coil has got too warm or isn't getting enough voltage/current, voltage drop due to worn ignition switch/old wiring/oxidised connections.
So I'd suggest starting with a service and tune up and then once that's all done and still having trouble get back to us forum peps 🙂
chrissys beetle ·
ok I will do a service
I will renew the electrics and let you know
Chriisy
chrissys beetle ·
whats the best electronic ignition brand to get
adlbeetle66 ·
Try Wolfsburg Automotive... I think it was called rapid fire ? Someone could confirm how good they are...
beetleboyjeff ·
I got 2 of these from Gary (Wolfsburg Automotive) at Valla (August last year), and the first one started to play up towards the end of November, so I put the 2nd one in, and it started to play up in February, so I put points back in for the moment.
I have also been keeping an eye on this thread to see what is good, and it doesn't seem like much is at the moment.
I was running Compu-fire for the previous 10 or 15 years, but I heard they have gone off in quality in recent times.
Pertronics seem to be the best these days. Altho I run points or MSD in my own cars
modnrod ·
matberry wrote:.......... Altho I run points or MSD in my own cars
Me too, points or HEI.
