Engine parts for sale - Sydney
https://forums.aussieveedubbers.com/threads/108911/engine-parts-for-sale-sydney
hus22l ·
Hey veedubbers,
I'm doing a bit of a tidy up and there are some things I won't be using any time soon so I thought I would put them up for sale. If your interested, shoot me a pm - I can then give you my number and we can discuss more if required, I can send photos if you need them.
- nos Mahle 90.5mm (a) piston and barrel set. Brand new. Still has the cosmoline covering. Imported from the states. Make a 1776 or bigger with a stroked crank. $380. SOLD
- nos Mahle 92mm (a) piston and barrel set. Brand new, still with the cosmoline. Though one has some surface rust on the barrel from not being stored as well as I had thought (grrrr). These are thinwall. So not recommended for a bus. $300.
Edit - I have had a closer look, two of these have been trial fitted but not run, there is evidence of a gasket product near the sealing surface. The price has been knocked down due to this. I can bring them to the nationals if your interested. I will be there early.
- used Mahle 90.5mm (a) piston and barrel set. Good for a learning engine builder or someone with a tight budget. Will need a hone and new rings. $100. Good to go, engine failed for other reasons (nothing to do with pistons and barrels).
Located in western Sydney. Fairfield area.
Phil
warb ·
sweet, ill take the new Mahle..
hus22l ·
Not sure what you mean Warb?
warb ·
hus22l wrote:- nos Mahle 90.5mm (a) piston and barrel set. Brand new. Still has the cosmoline covering. Imported from the states. Make a 1776 or bigger with a stroked crank. $380.
sure mate, ill take these ones, just don't PM me, PM box full apparently?.. drop me an sms? O423 II3 654
hus22l ·
Bump!
NOS MAHLE 90.5 - pending payment.
Can arrange collection at Nationals.
hus22l ·
Update
90.5 sold.
New Mahle 92s still available - see additional comments in original post.
Used 90.5 still available.
I also have stock 1600 twin port heads with rockers. Looking for $100.
norbert ·
Had a couple of questions re: the used or the new Mahle's. Could you send me a text so I can call you.
0414 275 995
hus22l ·
Text sent norbert, give me a call tomorrow.
hus22l ·
Also got:
- twin port heads - cut for 90.5/92s. Good used condition. No cracks. Can include stock rocker set up too if required. Looking for $250.
- weber carbs and linkage, air cleaners and twin port manifolds. 36 IDF dbbl carbs. Awesome bolt on for a 1600 + motor. Looking for $600.
Phil
