Aussieveedubbers 路 Buying, Selling & Swapping Parts
FREE (and some cheap) stuff Brisbane ~ nothing over $15!
https://forums.aussieveedubbers.com/threads/108913/free-and-some-cheap-stuff-brisbane-nothing-over-15
adlbeetle66 路
Need to clear some stuff out so here goes 馃檪
2 X Flywheels - $5 each
4 X Tappet covers - FREE
3 X Single Port Carby Manifolds (type 1, 3 & 3.) - $5 each
4 X Assorted Single port heads - $15 pair
6 X standard rocker assemblies - FREE
4 X Standard fuel pumps (unknown conditions) - FREE
1 X Beetle fan shroud $10
2 X Beetle Bonnet hinges and springs (1964) $15
2 X Single Port Cylinder Tinware $10
4 X Assorted Oil coolers - FREE
Can get pics if you need them...
Or more info 馃檪
Sms or call me on 0447 055 03 five
bushed 路
r tap cvrs 1600 pls 2 to me...
any 36 hp items or what hpor cc are they pls??
adlbeetle66 路
OK, will have a look....
Also think i have some 1100 heads and tappet covers (smaller i think?)
adlbeetle66 路
Here goes for pictures!!
OFFERS??
adlbeetle66 路
adlbeetle66 路
adlbeetle66 路
adlbeetle66 路
adlbeetle66 路
Bump... I do need this stuff moved.. probably 75% of this is free if someone wants to come over and take the lot? 馃憤
pudgy 路
Do you still have any of the cranks (mainly after the gears etc., but I'll take a whole crank) and tappet covers?
adlbeetle66 路
Yep.. got 3 cranks left... come take your pick...
Half a dozen tappet covers left...
Come and take it away 馃憤
adlbeetle66 路
Still want those bits pudgy?
Engine case, 4 tappet covers, alternator stand, cam, crank & conrods, and 2 heads sold today...
Hurry!!
pudgy 路
Yeah sorry I had sent you a PM...not sure if it went through. When is the best day and time to pickup?
adlbeetle66 路
Nup.. didn't get it 馃檨. Will send u a PM.
beetle_nut 路
Have you got any 36hp motor bits.
adlbeetle66 路
Have got some push rod tubes (they are quite small compared to the others i have..)
I have a really small head..
And a barrel or two maybe!
Sent u an email...
adlbeetle66 路
Nearly 50% gone!
Come and take peoples!
Strogger 路
Hi Mate,
Chasing a 12v flywheel to suit my 1300.
Not sure what else to tell to see if it suits.?
Need one with a good ring gear and machinable clutch face.
Thanks,
Anthony.
adlbeetle66 路
Yep.. standard 180mm Flywheel is there.. $10. 6 or 12 volt?
adlbeetle66 路
Bump, SMS sent Anthony...
adlbeetle66 路
Most is gone..
If you see something you want - ask!!
Need this all gone please!!
mossman 路
Do you still have the 12volt fly wheel?
adlbeetle66 路
Hey,
Yes, I have 2 flywheels left, not sure if they're 12 v or not though..
Do you know how to tell?
mossman 路
Pretty sure the 12 volt flywheel has 130 teeth. The 6 volt fywheel has less - maybe 109.
adlbeetle66 路
Just checked against a spare 12v 8 dowel flywheel i had, and its a 6v sorry.
mossman 路
Ok. thanks for checking. Do you have a dual port inlet manifold centre section with the preheaters by any chance?
adlbeetle66 路
No sorry.. only have the inlet manifold ends...
