hus22l wrote:Thanks mate, I'll give them a call.
Has anyone done it themselves? I reckon I can tackle the disassembly and clean etc, it's the testing after putting it all back together that I'm mostly concerned with.
They're pretty simple. Just take photos of every thing before you take it apart especially if an SVDA variety of dizzy as you'll need to photograph the mech advance assembly under the vac advance plate.
Once apart is first checking the dizzy shaft isn't badly worn. If it is it can be surface ground and nitrided to make it usable again. Then you can find online bronze split bushes to replace those in the dizzy body. Depending on the model of dizzy some types of wear in the advance plate can be weld filled and ground back. Then if the vac can is dead there are 2 types available to buy and depending on your dizzy the mount holes may need modifying.
I've done a few now including the old VJU4, I think, from the Oval and one of the big bodied vac only. Another i tried had a siezed shaft and the body crack when trying to press it out. Win some and ya lose some
So yea, if you're mechanically minded then should be pretty easy for ya
