Hot balast resistors
https://forums.aussieveedubbers.com/threads/109055/hot-balast-resistors
Cracka50 ·
Hi so im trying to get my wipers on my bus to work , noticed that the resistors i think thats wahat they are there are 2 maybe 10cm long and 1-2 cm wide.
They are gettting really hot. Any ideas?
ballast resistors do get hot when operating, just make sure they are clear of anything flammable
Cracka50 ·
Oh ok, that's ok then it's a new van to me and I just worried.
Any tips on why the wipers may not work, I replaced the fuse.
Is your van 12 volts ??
Guessing those resistors are for wasting 6volts as your wiper motor is still 6 volts
Do you have a voltmeter?
Cracka50 ·
Yea I do have one, it is 12v I'll have to show a photo of the conversion it's very funny.
my guess is the motor is the original 1200?? and a 12V generartor / alternator has been added
So the resistors near your wiper motors are just there to waste 6 volts
Cracka50 ·
Oh ok, that makes sense.
1200cc hey lucky for reduction hubs ha ha
How can you confirm engine size??
what is th number under the genny stand?
adlbeetle66 ·
Yep.. engine number under generator stand..
Match it with here:
http://www.clubvw.org.au/vwengines
Cracka50 ·
But that wouldn't show if it's been rebuilt and is a 2.3 stroker ha ha would it??
126-030601
But I'm not sure how it works is the code the 1st number ie. 1?
adlbeetle66 ·
😂 No, it wouldn't.. it would only show the original size ~ which isn't much help 😂
vwo60 ·
This will fix your problem, works well in two of my cars
http://www.ebay.com.au/itm/VW-BUG-TYPE1-WIPER-WIPER-CONVERSION-KIT-EMPI-9344-/161104969204#ht_1157wt_1362
Cracka50 ·
That looks the goods, so I would be removing the ballast resistors and going 12v to the wiper motor via this thing.
If it happens that they arnt working because the wiper motor is broken can you get a 12v motor ???
i would say you are more looking at getting your motor rewound to 12 volts
i am not knowledgeable with splits so have no idea what 12 v motors would fit
Cracka50 ·
Yea understood, I obviously have a lot to learn myself.
vwo60 ·
If your motor is 6 volts and works ok then the above device will work , as it does on two of my cars with 6 volt wiper motors, it is even variable speed.
Cracka50 ·
Yea nice, but if the car has been converted to 12v domi just remove the balast and go 12v direct using that adapter?
vwo60 ·
yes, as above.
