Endfloat - Distributor Driveshat
https://forums.aussieveedubbers.com/threads/109156/endfloat-distributor-driveshat
landfall ·
Using 2 x .6mm (.023") shims I have only .007" endfloat in my driveshat.
It seems that you can only purchase .6mm shims?
The Wilson book states that a minimum of .020" endfloat is necessary, but the Bentley manual does not give any measurement.
Any suggestions please.
psimitar ·
Um, so one shim would give you 30thou clearance.
Or you use some 180 wet n dry lubed with WD40 and sand the shims using a figure of 8 motion to give a flat surface.
Beyond that try the UK or USA vendors as they are normally far better stocked than the Oz vendors.
landfall ·
psimitar,
Thanks for taking the time to reply.
I did try and wet and dry the shims, but they are hardened and my fingers are softening.
Managed to change distributors and this gave me the correct clearance.
psimitar ·
Cool glad you found a solution. Another option for hardened shims is clamp your grinder in a bench vice and then with a 1mm slitting disc you hold the shims in a molegrip pliers and use the slit disc as a version of a surface grinder. With a steady hand you can get good results but of course WH&S would have a field day with such a method being used. 😂
cb john ·
🤪 have you heard about surface grinder?
psimitar ·
cb john wrote:🤪 have you heard about surface grinder?
Yes, my dad used to use em all the time as a toolmaker 🙂
landfall ·
Yep, have you heard about ridiculous labour charges?
cb john ·
🙂For no or little money, no or little music...
HappyDaze ·
Lot of fuss over a little washer. 😉
psimitar ·
😂 😂 😂 Nail on the head dude 😂
Hence my cheaper solutions 🙂
