Preferably with everything in tact ready to bolt on, but parts is fine too.
Do not mind if it has adjusters
Text me on 04 0734 5644
alansvw ·
I have a King & Link Pin front end from my 61 ghia but it has disc brakes fitted from 60's. Have removed from car and brakes are off the beam, also includes sway bay. Not sure what to sell for as happy to keep if my new imported front beam does not pass engineering I may need, but if you make an offer. I have photos if wanted.
JoshJazza ·
i have the drum wide 5 stud drum brakes, will they fit straight on? would the beam come with all the tie rods and leaves ect?
photos would be good if you can put it up.
grumble ·
Josh if that doesn't work out i have a beam in Taree but will have to check what is missing.
Cheers Les
sgetty ·
I have one in Bendy, heading down to pokolbin this weekend but not sure if i will have room unless i strap it the beetles roof rack..
will text ya a pic
alansvw ·
here was the beam before removal, I had wide five wheels on it. Includes Koni Shocks and master cylinder.
