I am restoring a 61 pan from a buggy however the pedal assemble was badly rusted and missing parts
I have purchased what's in the photo
Can someone tell me what I'm missing
Cheers Charlie
OZ Towdster ·
Your missing the passengers side mounting/ pivot and the passengers side throttle lever and circlip / split pin , and hows the hook on the clutch pedal on this set as that is usually the most WORN part
adlbeetle66 ·
And dont forget the rubber pads over the top 🙂
4reel ·
What's the passenger side mount piece look like.
Found the accelerator lever and rubber on classic vdub .
We're would I find the other part.
Thanks for the replys
bushed ·
S shaped pedal to accelerator shaft with 2 retaining springs (I have)
plus rubbers I have
and a accell cable
cheap to post
B
4reel ·
Thanks bushed I've got those pieces from George just need that side piece
Charlie
bushed ·
gotthe cvr plate if u want it pls email
4reel ·
Yeh mate I'll grab it
Pm sent
4reel ·
I still can't find this part if anyone has one or knows we're to buy one.
Charlie
adlbeetle66 ·
Think i have one.
Will let you know
4reel ·
That would be great if you have it.
Also need the accelerator linkage
bushed ·
what the Z dooverlackie???
4reel ·
This
Trendy ·
Left or right hand drive? Doesn't look familiar to me but could be throttle cable thingy to beaket foot pedal?
I have been fixing brakes and clutch pedals and stuff in my 60 bug and doesn't look like anything?
4reel ·
Right hand drive
That pick was from classic vw
4reel ·
Come on someone must have a spare side plate
No one seems to sell this part aftermarket
Charlie
adlbeetle66 ·
Having a look for that and the acc linkage on saturday mate
donn ·
I keep thinking there's a small roller missing from the right hand end where the accelerator peddle operates the shaft ?
hus22l ·
How did you go with the overhaul? Any tricks or tips?
I think I need to pull out my pedal cluster and have a good look at it. I have a clutch issue, which might be the worn "hook". At the same time I am pretty sure my accelerator is not as it was intended to be..
Is there any good upgrades to the stock setup? I can see there are aftermarket bits that appear to be improvements - but these are American - so set up for Left Hand Drive.
Camo ·
hus22l wrote:How did you go with the overhaul? Any tricks or tips?
My suggestion, throw the F**KING accelerator section away.
I've just come in from stuffing around for 4 hours straight with my 61 Beetle accelerator and it's worse than before.
Not a good time to reply as I have the shits. But unless you have anything but a standard setup, toss it in the bin.
Had the accelerator rod guseted from where it comes out of the brake pedal assembly and it still f**ken bends and wont get full throttle.
My 2c worth 😬😬😬😬
bushed ·
EMAIL ME IF NOT SORTED
YOU WOULD DO BETTER IN THE BUYING SECTION FOR PARTS ALSO
b
hus22l ·
Yikes! Camo hope you get that sorted. Bushed, thanks for the offer.
